bassboy416
Thread starter- Joined
- Jul 9, 2013
- 79
I posted this before, so forgive me if I sound repetative. I've been doing a lot of internet research and have become very concerned about this issue. I have an 86 or 87 alpha one outdrive. I got it last year and it was making this noise when I bought it. I have taken it out for 6-7 times since I bought it. The outdrive makes a loud vibration that almost sounds like "hooooooooooooonk". Its very loud, you can feel it vibrate the boat, and it goes away when going straight if you trim up slightly. I have become suspicious of the gimbal bearing although the previous owner said it was probably u joints. I have been wanting to take the boat out wakeboarding one more time since I fear that this may be the end of the road for me if it turns into some crazy expensive or difficult repair. I bought the boat cheap, and I do not have 3000 to put into the thing. Is this most likely a bad gimbal? It does take on water as well and the transom housing (the part that contacts the boat) is siliconed around the edges as if it was leaking. My question is this.... Is this most likely a lost cause and something I should just drive until it dies or is there a possibility I can repair myself for 500 or less. I am afraid if it is the gimbal bearing that I may have caused damage to the gimbal housing. I am also unsure about the bellows replacement. I found a "transom repair kit" on ebay for 80 bucks, and I found the special tool for removing and replacing the gimbal and checkign alignment for 250. I have no experience with outdrives but have worked on a lot of projects with great outcomes. Can I take it out one more time? What am I looking at here worst case? Are there any special tools I will need? Also, when removing the outdrive, besides putting it in forward, are there any tips for getting it off if it is stuck hard on?
