That could be it. One other test i always do is to grab the flywheel and try and push it in different directions to check for play. A hairwidth movement is normally found, i think laterally and even less is found normally forward and back (might be vicer versa). Just checks the bearingsThanks Bos. I am running it in a barrel, I think maybe you are hearing the water bubbling out of the test tank?
