g0nef1sshn
- Joined
- Feb 24, 2015
- 1,291
What stripper is the best at stripping and which is the easiest to work with and clean up... Once I use stripper and wash with soap and water, do I have to do the polishing thing... does anyone suggest leaving the bottom bare, and if so what technique did you use... I have put some Gluvit on the stern area inside rivits and it turned a little yellow... I wounder if that might be a good bottom paint... also can you paint over Gluvit... Mr. WaterMan... That is a fine job... Is that primer paint , if so who's did you use...![]()
Kleen strip worked the best for me, but burned upon skin contact. The citrus stip also worked, just not as effective on burning though multiple layers of paint in one shot. I left most of my hull bare on the bottom. Figured I could always paint in the future if I need to and no one really ever sees it unless they look at your boat trailer while its on it. Or they are snorklin?
[/URL[URL="http://s1290.photobucket.com/user/FordPsyco/media/20150915_276_zps4skn07ab.jpg.html"]
