Need info on where to look for specs on buddies boat please
nigels
Hi Guys. Yesterday I helped a bud try out his just bought 1994 2252 classic with 4.3 Mercruiser. He put 65 liters of gas which topped up the tank to 7/8ths full. Off we went but the boat would not get on plane, (his trim tabs did not work which did not help) at 4800 rpm it was doing about 20 knots but it still did not seem to be planing well. Water was flat no wind. My own boat trophy 2052 with same engine is skimming along at 3400rpm doing 20+knots so this is what I am comparing it with. At 5500rpm for 30 seconds we got 25 knots.
So in total about 10 minutes of 4800rpm and the rest about 45mins pottering along at about 5-6 knots at 2000rpm, which I thought was also very slow, my boat will do, I think, 10-12 knots at 2000rpm. Need to confirm that.
Anyway the boat died after the hour and about 10-12 miles distance. We started the kicker which also died, both fed from the same tank. Fuel gauge reads half full but tank is empty knocking the SS tank sounds very empty and confirmed when friend brought out gas and no fuel problem was resolved. So gauge or sender needs attention. Tank is new. Leg was replaced by previous owner with a recon unit not sure if gear ratios are correct. No gas in bilge.
Here is the point, we used at least 65 liters possibly more as there was some gas in the tank before, for the above scenario and the boat seems to be dead slow, which says to me that the prop or ratios could be wrong, or is that just how this boat is. since it has a 50 gal tank then the range cannot be much??? Are there any 2252 owners or anyone in the know about this boat with this engine that can shed some light?
Where should I look to find specs on what prop it should have and what gear ratios should be in there? .
Any help would be greatly appreciated, the couple who bought the boat are such nice folks, you can imagine their disappointment. all advice appreciated.
Sorry for long post.
steelespike
I guess we need to start with the Prop size,near the base of the blades or under the prop nut.
​ What is the hp? 190? 205? etc.
65 litersd is about 17 gallons.
If the motor is a 190 it will use about 20 gallons per hour at wot.Less at lesser throttle settings.
at the least it appears the prop is way too light.
Bayou Dave
I may be way off base but think that 5500 rpm's is way to high for a 4.3.
nigels
1994 4.3 I think its the same as my 1999 4.3 so I guess 190hp. I will get the prop size and engine number to confirm HP next time I am over there.
