FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
thanks, so my multifunction tach has 2 large clips ( 1red, 1 black) that assume go to the battery, then there is a small red, yellow and black clips.
So your saying just attach the small black clip to the negative side of the coil.
What do you mean by "tach + lead"
You never said exactly what brand tach you wanted to use so I generally gave the hook up for a dash mounted tach.
The red and black power clips are most likely correct the others I cant say. what do the instructions say about hooking it up
The brand is RAC, I dont have the directions. But fiqured that they are pretty standard, I just have never used one before, also I have read that there may be a service wire that you can clip into? But I cant seem to get it to work?
Have a photo of the back side of the tachometer gauge?
Also look around the top of your engine because "some" engine models offered a loose gray wire so you'd be able to connect an external shop tachometer such as the gray wire hopefully seen below with the black plug in it.
