Model number of Globe Run-Dry impeller for Gen 2?
JASinIL2006
I'm trying to find a model number for a Globe Run-Dry impeller for an Alpha One Gen 2 drive. In the part lookup, I can find an equivalent for an Alpha One, but I don't see any for the Gen 2. Has anyone ordered one of these for a Gen 2?
achris
More fish than mountain goat
Having done a fairly thorough search of their website, it doesn't appear they make one for the Gen II...
JASinIL2006
I was wondering if that was the case. I wanted to make sure I hadn't missed something...
Maybe I'll just order OEM.
achris
The OEM ones are pretty tolerant of dry run too. Being long vane makes it better at cope with a 'no water' scenario.
Chris.....
Fun Times
If no one chimes in with what part number fits the Gen 2 Alpha then you may have to try measuring the dimensions including the keyway holder of a new OEM impeller and look around the website to see if you can come up with a match 'size wise as they list them on their site.
Using the websites Search by Manufacturer, only one style impeller comes up and it appears to be for the non Gen 2 Alpha drive, https://www.gcsmarine.com/store/index.asp?show=pdet&pid=178
Without knowing the actual dimensions of the Gen 2 impeller and quickly looking around their site, it "appears" they may not offer one for the Gen 2 Alpha drive.:noidea:
Hope you can come up with something without too much trouble, good luck.:)
achris
That's how I determined there isn't one for the Gen II..
Ayuh,.... That's to bad,.... I'm convinced, they're the Best,....
