grady86
Thread starter- Joined
- Feb 19, 2014
- 32
1989 3.7L Alpha One.
It's been a frustrating weekend. After installing a new transom repair kit (bellows, gimbal bearing, gaskets, o rings, water hose), I tried putting the stern drive back in. I lightly greased the shaft splines, put it in forward gear, and got the stern drive to go until it had about 2 inches, and now it's s.t.u.c.k. Tried giving it some love, but no luck. So, I thought maybe I should pull it back out and see what's up. Well, the thing won't budge. I had an extra helping hand, still nothing. I attached two pictures. Some tribal knowledge would be much appreciated.
Here's some amplifying information as to what types of measures I've taken.
Once I started contemplating anchoring the drive to a tree and yanking it out, I decided, "You know what, self, maybe it's time to go post this in the forums before I break something." You guys are great and have never failed me before. Thanks again, I already owe so much beer to this site!
-Grady
- The drive moves freely with a couple centimeters of slack up, down, left, and right. It is not stuck on any of the 6 threaded lugs whatsoever.
- The male and female ends of the shift mechanism under the bell housing are not making contact with one another yet, the drive still isn't close enough, so I know it's not binding up there.
- I lightly greased the splines with all purpose marine grease before trying to install it.
- I engaged the drive into forward gear manually and then tried tapping the prop with a rubber mallet.
- I also attempted to crank the motor slightly to see if it would maybe jar the splines loose if they were jammed.
- I used a rubber mallet liberally on the drive to see if I could jar something loose that way...
- Finally, I slid a rope between the gap of the drive and the bell housing, and used a come-along to apply good amount of pressure to see if that would pop it loose. This just seemed to cant the drive against the studs, since it wasn't a directly straight line-of-pull...
- And, of course, I have spent hours just trying to man-handle the thing off of there.
-Grady
