nateo
Thread starter- Joined
- Apr 13, 2014
- 352
Ok, I'm in it deep here with major time and money. Just fixed bent valve in head. Forgot to mark distributor before taking it out. First I tried moving engine to tdc with a socket wrench placed on harmonic balancer. It seemed like engine moved a little bit but it also seemed like I was just tightening up that bolt so I stopped with that. Did I screw something up with that attempt? Ok so I found a thread that suggested placing finger over #1 and feel for compression while trying to get timing mark close to 0. Then point rotor at #1 cylinder. This is steps I followed to stab distributor. Ok so have everything back together and engine turns over but won't start. It's clearly backfiring out of carb. Engine kinda sounds like its farting when it tries to start. I know timing isn't correct but will that prevent engine from starting? How do I adjust timing if I can't get to start?
