Dolphin210
Thread starter- Joined
- Aug 2, 2005
- 5
OK, I am guilty of running a 1970 Evinrude Dolphin 210 (Old OMC tri-hull) accross a lake at near-full throttle with the trim about 3/4 of the way up. As a result, the teeth on both the gear at the end of the drive shaft (protruding from the back of the transom delivering power to the outdrive) and the receiving teeth on the outdrive gear have been sverely sheered, to the point that they will no longer mesh together and deliver power to the propeller (in either forward or reverse). Does anybody know what these 2 gears are called, and how to order/remove/replace them?
