Trailer tire pressure?
smokeonthewater
I didn't say anything about a margin.
I don't see any need for any margin....
Neither do you if you deflate a tire to match the load since that effectively removes any margin beyond what is designed into the tire.
The margin is built in .. If the manufacturer rates a tire to carry x load at x mph and x pressure it isn't going to fail at say 10% more... They rate it for what it can reliably do, not 2 lb under the failure point.
Nope, I keep it inflated so I have more margin.
In any case. I wouldn't have 2 1780 tires for a 3400 pound load but that's just the engineer in me.
smokeonthewater
Would that maybe be the engineer who doesn't trust other engineers?
Soooo you inflate your trailer tires to max????
bigdee
Not worth arguing about guys. Bottom line is you can't go wrong by inflating to maximum. Unless you know what your doing adjusting pressure can be catastrophic!
