FirstRealBoat
Thread starter- Joined
- May 24, 2015
- 126
It's me again, with this same motor as before, 18HP Evinrude 1967.
I just put new coils, condensers and points in. Along with a new water impeller and fresh LU oil. So I was ready to test and hope to get out on the lake soon, well maybe not.
This is the issue, I will explain it best I can. Pictures won't help with this, unless I need to take Flywheel off again then I can show you all the top.
When spinning the flywheel I can feel resistance only on half the spin. I figured it was the magnet that was giving me resistance, not that the top is back together and I started the motor I am not so sure. The motor will run, but takes 5-10 pulls to get it to start, then I have to have it idled higher than normal to keep it running. If I lower the idle, I can hear and see the brass fin on the distributor jump backwards and then I hear the click. Like there is something getting hung up. I looked under the flywheel and can't see any new damage. I have the coils set flush with the blocks that it sits on.
When twisting the tiller handle, when flywheel is on one side. There is little to no resistance, once the flywheel moves around 180 degrees. There is noticeable resistance and a noticeable pop or pop off point is felt.
What am I missing?
Thanks for looking
What am I missing?
Thanks for looking
