Air bubbles in the fuel is pretty normal so that doesn't indicate the fuel pump is failing. If you have a primer bulb on your fuel line you can also confirm this by simply squeezing the bulb or priming in any way, when the motor stumbles, and if it revives when you do that you know you have a fuel pumping problem that may or may not be the fuel pump.
