:welcome: gpmck to iboats. Nice to have you aboard...
I guess the real reason that you received no replies because it is hard to imagine such a tach problem. And usually folks will not offer any suggestions if they have no idea what the problem could be. My only idea is that you either have the signal wire and ground reversed on the back of the tach, OR a bad tach. Knowing how a tach actually works, I can't see any other possibilities myself. If you can, try another tach hooked to the same signal wires and see if that tach works properly. If that tachs also runs in reverse, then you verified your problem is at the engine. If the other tach works correctly, then you have a bad tach. A simple process of elimination... :noidea:
