mark123456
Thread starter- Joined
- Jul 9, 2010
- 25
I have a 2006 bayliner 205 with alpha 1 gen 2, after reading through the manual it says something about most current mercruisers have the mercathode system factory installed, I don't think mine does, where is it, I assume there should be a 110volt plug somewhere. The boat came from 100% fresh water area and I am using it in a 100% salt water area, should I consider adding the system, I leave it in the water all summer. Also would the anodes be aluminum or magnesium because it came from a freshwater area, I removed some and they feel pretty light, can you buy zinc anodes for these drives? Last summer It was moored in salt water for 2 months and the anodes show very little corrosion compared to outboards I have had with zinc anodes. Does the mercathode system protect any of the internals of the engine/manifolds as well?
