fmt2bx
Thread starter- Joined
- May 27, 2015
- 217
Bad day!!!
Motor has been running great and suddenly, running rough seems more like misfiring than fuel starvation.
At idle, runs a bit rough but not too noticeable. RPM at 900 to 1000 today (neutral), usually 1100RPM.
When opening throttle, seems ok at first then motor starts to run rough, vibration. Then smooths out but I could hear a slight "bang" noise.
After stopping engine for 20 min, engines runs ok all the way to WOT, then as it warms up it starts to run rough again.
Very erratic though.
When motor runs ok I only get about 4200 4400 RPM, usually getting 4800.
What I did so far:
-Changed spark plugs.
- Fuel pump ok, (in line filter more than 3/4 full). Fuel filter clean.
- Cleaned and Checked grounding from Coils and ignition box.
-Checked spark plugs wires seemed ok
How should I proceed from here? Any suggestion ?
Thank you.
Cheers.
What I did so far:
Thank you.
Cheers.
