kramerpage
Thread starter- Joined
- Jul 26, 2010
- 447
So I went to install my new seal and found that there are three small ears on the bore below the bushing which I did not replace. So the seal would not install from below going up into the housing. I then filed the ears off and coated the bore and seal with perfect seal. It is correctly seated now but I don't feel good about it. I'm concerned it might fall down over time. The number 6 manual is very veague at best on the procedure. Please advise the correct procedure. The outside of the seal is rubber where it meets the bore. I read on Jr marine to use loctite but that was a Bravo drive. I'm gonna stop for the night. Thanks so much guys.
