mvd2bze
Thread starter- Joined
- Jul 17, 2015
- 21
Last weekend, I bought a 1987 Galaxy Admiral 189 with a 130hp Merc Alpha One.
I brought a professional marine technician with me to inspect the engine/drive and hull, since my boat knowledge is limited to passengering/driving and assisting with outboard motor work (Evinrude Lark III, to be exact). Long story short, we missed water in the oil, and now I have what is probably a cracked block and more.
I'm hoping that I can describe the symptoms and folks with lots more experience than me can give a best-guess as to what happened here.
The previous owner has documentation of a winterization he paid $250 for last year.
He ran the boat three times this season to show to buyers.
I ran the boat for a few minutes without incident the day I bought it. (Since he said he had just run it, and the mater muffs were still attached, I didn't think to check the oil. (He had classic cars on the property in various states of restoration, so I trusted he knew not to run it low on oil, and did not consider the oil may be contaminated)
The bilge was showing traces of sludge, as was the transom plate.
Yesterday, in preparation for it's maiden voyage under my ownership, I connected the water muffs and checked the oil prior to start. I saw the oil wasn't just oil; it had some obvious traces of water in it.
After discussing the issue with my pro, we decided it might have been condensation and opted to start it up and check the oil after a minute (wishful thinking).
When the idle started to smooth out, I brought the revs up to about 2200rpm for a few seconds and planned to turn it off, when water from the PCV tube shot into the carb and stalled the motor.
When I checked the dip-stick, I found water about four times higher up on the stick than the "full" mark and the full extent of the problem washed over me.
I started the motor for another five seconds later to show my pro what was up, and also noticed oil/sludge pushing out behind the starter, probably from the rear main seal.
I have been in touch with the seller, and he has talked to his pro who winterized it and offered apologies and possible compensation. Due to his complete surprise, I am opting to trust him for the time-being and entertain the idea that something strange and not simply a cracked block is happening.
This leads me to my questions:
I will begin disassembly today, if the rain lets up, but can anyone offer any thoughts?
I'm really wishing I had shopped for a closed-cooling motor right now. Oh, and checked the frickin' oil before purchase!!!
Thanks for your educated assistance/opinions!
- Is there really anything other than a cracked block that could cause so much water to get into the crank case?
- Is it possible that high water hose pressure could cause any problem like this? (I know... grasping at straws)
- Can a head gasket be responsible for this, and structural integrity is still ok?
