bob johnson
Thread starter- Joined
- Feb 25, 2009
- 4,306
so I just fired the boat up after not running since feb...started right up!, I was going to de carb the motor and I let her warm up at 1100 rpms...if I tried to push it to 1200 the tach died. but the motor ran fine...I sparayed the decarb and while I am letting it smoke out I noticed the tach would die off and restart...but the motor never skipped a beat....
View My Video
is the rectifier dying?
second question is that one bank of the motor is always hotter than the other...same side all the time...one head is 170 degrees the other is 120 degrees....it sometimes approaches 185 on hot days with a warm body of water at idle rpms.... once I raies the rpm and the water pressure rises to about 20lbs the temps cool off to the very low 100s.
so it insufficient water at idle, when I took the muffs off I plugged the hose right into the flushing port, and even squirted a little dish soap in the port and I ran the water for 10 minutes. the one normal bank got cool very quickly the other was still very warm to the touch!.. eventually the one head was forming condensation there was so much cold water running through it. the other side was still warm!!
where could this blockage be??? is there a known place that can clog??
1995 Johnson 115 ocean runner....60 degree looper OIS motor
thanks
bob
View My Video
thanks
bob
