Bravo 3 seems to be building up pressure
maxum3300
Yesterday I checked all my fluids in both motors and I noticed the port motor gear lube bottle looked like it was full to the cap. I removed the cap and gear lube went everywhere. Cleaning up the mess caused me to spill more to the point where the gear lube level is now down to the bottom of the reservoir cap neck. While i was cleaning the bilge I noticed the gear lube level slowly rising. This is all happening with the engine off. What would cause the drive to build up pressure like this?
Sounds to me like your drive has a leak and water is getting in. Your bottle was under pressure from the extra fluid. During the clean up process it had more time to equalize the pressure up the very small hose leading to the bottle. I would suggest pulling the drain plug on the drive and check
maxum3300
If it had water in it wouldn't the gear lube be milky? The boat is in the water so I'm not able to drain the drive without pulling the boat.
maxum3300
Also if water is getting in wouldn't gear lube be getting out? There's no visible signs of a gear lube leak in the water.
No, the tube feeding the bottle is pretty small, and over time, the mix could make it up through the tube but IMO before that happens your drive would be damaged beyond repair.
Understand the larger boats is an issue. I'm guessing based on what your telling us. You could get in the water and rotate the prop by hand and feel and listen for anything. Compare it with the other drive
Maybe, but your bottle is over flowing, while there is probably small amounts leaking out, its to small to notice. Probably only be doing it while running.
HT32BSX115
Absolutely Right.
It doesn't take much water in the drive to produce pressure once the drive gets hot.....just a few teaspoons will produce a fair amount of steam.
Your seals can start leaking in both directions but not always at the same time. I.E. It's possible that they'll hold a fair amount of pressure but won't hold very much vacuum.
The drive heats up and while cooling, the drive lube monitor will slowly allow oil to flow back into the drive as the small air pocket "shrinks"
If any of the seals start leaking during the vacuum produced during cool down, some water can be sucked in through a leaky seal..
You NEED to get that boat out of the water and drain some drive oil to inspect for water intrusion (I would do BOTH)
If you drained and refilled the drives last winter prior to winterization and there was no evidence of water, you may be catching the leak early. If you didn't, the water may have been in there for an entire winter (and there may be damage already)
The earlier you catch it the better. There is an ASTM specification for hypoid gear oil to still provide adequate lubrication even when contaminated with a certain amount of water. So you may be just fine. I would not wait though.
Regards,
Rick
