Mr upper shift shaft seal
bigbob_FTW
Worn out and leaking. I can't get the setscrew on the lever arm to budge. Is cutting the shaft a viable option?
Bt Doctur
drill a hole in the arm, and hit it with a chisel to split the arm, then remove the screw.
bigbob_FTW
Ended up drilling the shafts in two. Expensive little sucker.
