mnypitboat
Thread starter- Joined
- May 31, 2010
- 1,091
outdrive oil leaking inside boat. reservoir part number? 2008 Mercruiser 5.0 Alpha one
OK this is driving me nuts. I cant find a leak anywhere, but a 30 minute trip on plane and the reservoir is empty and its all in the bottom of the boat. I replaced the cap thinking it had lost its pressure, but its still leaking. There is no visible leaks at idle or off. I pulled off the reservoir and filled it with fluid and put it in a bench vice and let it sit a week and it did not leak. The line going all the way back seems to be fine.
The only thing I can find is a bit of oil underneath the reservoir, but I am not sure if that is from me missing the hole when refilling it.
So any ideas? If I cant find anything else I will just buy a reservoir I guess. Only one problem with that. I cant find my reservoir part number anywhere. It looks like the rectangular one that is held in by what looks like a rubberband, but mine is mounted with a bracket instead and has a hose pressed onto it and goes back to a quick disconnect plastic fitting behind the engine. Any idea on a part number?
