Flooding Edelbrock carb Carb
Will Sea
This is a new build 1985 260 w/ Edelbrock 1409 carb built by a friend of mine Ray who owns Storm crank ( yea its a plug for him). Engine is solid and runs great. Only problem I'm having is sometimes the carb starts flooding real bad at idle. I haven't checked fuel pressure yet but I know it has to be around 5.5. In the likely event that I need a fuel pressure regulator dose anyone have any suggestions? Also If a fuel pressure reg is installed will it cause problems with the fuel pump OR is there a fuel pump I can use that will put out 5.5 lbs pressure. Thanks
gm280
Well it easily could be the fuel pressure, but it could also be a sticking float in the carb too. I would verify the carb is good before opting for a fuel pressure regulator. JMHO!
Will Sea
When the flooding happens engine is at idle and died, throttle at idle.Gas comes out in a steady drip. I remove Metering rod so as not to bend them,open up top of carb to check floats and they seem ok. Put every thing back and it seems to run fine. I doesn't happen all the time. Now I'm wondering if it 's the fuel pump. I don't recall seeing 2 gaskets on it. Also can't seem to get info on what the fuel pressure is on a mercrusier fuel pump.
Fuel pressure should be between 3-7 psi.
Don't see your issue as being a pressure issue, it more like a worn needle seat, needle valve or float sinking or adjustment as GM mentioned
