- Joined
- Mar 8, 2009
- 44,673
no sir. Where is the valve and how would one measure pressure? Also, why only after a great run on plane and after it starts cooling, then to be perfectly ok when cool again? That's the variable I do not understand.
The anti-siphon vale is on the tank and is the barbed fitting that your fuel line connects to. I did say replace but need to check it to see if it is hanging. The valve is a check vale, has a spring and ball in side it, so if you fuel line springs a leak it will not allow all the fuel in the tank to siphon into the bilge. If the ball gets crude on it (you been having trouble with crud in the tank) then the ball can hang closed/open or cause a restriction.
To measure fuel pressure get a $20 vacuum fuel pressure gauge and put a tee fitting inline between pump and carb. You should have 4 to 7 psi at idle and should not fall below that during higher rpm.
As to why your symptoms keep changing, hot, cold, fast then slow, don't know exactly yet. I will say that if you have crud floating around it can cause the engine to run poorly one time and a little later that crud gets passed and start running good again
http://www.harborfreight.com/fuel-pump-and-vacuum-tester-93547.html
http://www.iboats.com/Moeller-Aluminum-Anti-Siphon-Valve/dm/view_id.392106
