Mark_VTfisherman
Thread starter- Joined
- Nov 29, 2008
- 1,489
Pictures later... I have the aforementioned Holiday nearly gutted.
Problems are many but I own the boat and have a good 90HP for it, and it's got a great Cox trailer.
- stringers are all loose with too-small 1/8" pop rivets. some missing at this point
- a redish, purpley rubbery substance was poured into the hull at several locations along the keel. This will need to be removed. It leaks from the keel and several other rivets near the chine when flooded with water.
- transom is shot. Plan is to replace at full height, fill in aluminum at the cutout, and add several more knee braces. Then fabricate an offshore bracket kind of affair. That will save almost 30" of deck space formerly used up by the splashwell.
The question I have today involves the side panels. The panels I took out had the lower aluminum "foot" /on/top/of/ the carpet/plywood, but it was angled into the hull space a lot and didn't look quite tight. Didn't look right at all, and a toe-biter. Is the OEM arrangement to have this foot piece under the flooring? I can't tell as this floor had been replaced once already along with the carpet. Just looking ahead for install thinking. More questions down the road I am sure
