new engine oil pressure going down
betayv
hello guys 1987 mercruiser 350, was rebuild, when start the engine oil pressure is about 40, when engine warm up pressure go down to 20 and bellow, If I accelerate the engine pressure goes to 50 -60, engine oil weigh is 25w40, new oil filter, any advice thanks.
Alumarine
Your oil pressure will go down when the oil gets hot. It gets thinner.
7-10 lbs per 1000 rpm is fine.
achris
More fish than mountain goat
Sounds normal to me....
BTW, the oil pressure spec is 4psi (minimum) at idle, 30-60psi at 2000rpm.
flipbro
My new 5.7 runs 20 at idle at operating temp and a tad over 60 at wot
biggjimm
A lot of (most) guys get all wound up about oil pressure & hi volume pumps. Granted, not having pressure is definitely a bad thing but it doesn't need to be 80 psi at idle. In fact I have seen a couple instances where too high of oil pressure has actually blown cam bearings out. If you're main & rod bearings are in good shape or if the correct ones have been put in a rebuild, then a standard oil pump is more than sufficient. Your oil pressure sounds good. Enjoy that boat, summer is almost over, at least here in the midwest.
achris
:thumb:
