Too low at the stern ?
lawrence101
hi folks , first time boater and first post /question. I ran my boat thru its " sea trails " (i.e on the pond) yesterday and it appeared to sink alot lower at the stern when I gave it just a small amount of forward throttle. Is this normal ? Ive heard this is called "getting out of the hole" but how deep of a hole are we talkin ? Ive lowered the engine to its max trim , maybe the engine is too heavy for the boat? Its a 75hp evinrude etek, boat LOA is ~16ft + 16" engine pod, fiberglass over wood hull.
littlerayray
Need more info on like is there water coming over the transom and when you do take off the sterm does dip a bit or seems to and the bow rises you have to play with your trim
GA_Boater
Measurements won't tell us much with 16" setback pod. But pics will and some of the boat sitting dead in the water.
lawrence101
Thanks for replying, Ray there isn't any water coming in over the transom and im not sure what you mean by measure from bottom of the boat to the prop ? The cavitation plate is pretty much level with the bottom and the trim down is at its max.
lawrence101
Hi GA thanks for replying, I will try to get some pics of the boat on the water but it sits quite level at rest and when it gets on plane. its only when I first throttle up. For what its worth ,Heres a pic of it sitting on the trailer about to be hauled off for sea trials.
GA_Boater
Nice rig! What brand is she?
Is the bottom of the pod even with the bottom of the hull?
lawrence101
Thanks GA , I built it from plans , took 5 years ( of summers ) to get to this stage. The pod is roughly 2 1/2" above the hull.
Ray it was about maybe 1/4 throttle.
jbcurt00
Cav plate is even w bottom of the POD or the BOAT?
Thats a lot of setback, did the plans specify the 2.5" above the bottom of the hull? Plans for pod were for a similar size boat w a similar type hull bottom?
lawrence101
jbcurt, its level with the hull not the pod. The pod was an add-on not part of the original plans. The pod is 2 1/2" above the bottom of the hull because of the drain plugs. So you think the pod was a bad idea ? Ive only heard and read of good reviews for pods ,not much about the cons.
GA_Boater
+1 with Smoke. I think she's dropping at the stern as most boats do. You need more throttle to push her through the wallowing up to plane.
Do you have much boating experience? I know when I started mumble-mumble years ago, I thought the stern was gonna go under. You kind of lose your reference when the bow lifts up and you have to trust that she will go on plane.
You did the nice job. :thumb: What plansdid you use?
lawrence101
GA ,I have very little boating experience and I have practically zero experience with an outboard, this is my first boat, im learning on the fly.
The plans were from an old 1976 boat builders manual called sea angler, not very detailed but enough to get you started. Yes that was my thoughts exactly , I thought the bow was rising too much and the transom would go under.
Noobguy
Maybe trim tabs? Smart tabs are pretty inexpensive and worked wonders on lifting my stern. Maybe check the bilge, too? I find a leak in my exhaust gasket that bogged me up good. Just my thoughts.
Also, post ALL your questions. The only stupid question is the one not asked. These guys have helped me immeasurably, and learning to do things yourself saves money, but the pride in diy is a powerful thing. Welcome and gl
ondarvr
If the AV plate is even with the bottom of the hull it's too low, you will need to raise it up several inches for it to ride at the correct level. Having it too low will cause the stern to dig down deeper when accelerating. But, what you describe is normal to some degree on all boats.
phillipgo
That is a sweet looking boat, you must be very proud. I like Lenco trim tabs. They would keep the bow down, therefore raising the rear. Enjoy!
