Fuel line size between carbs on 78 75hp Evinrude
shawn.54
Want to replace fuel distribution lines on my 1978 75hp Evinrude do not want to disturb lines until I get new to replace them could anybody tell me what size line I need thanks in advance
Shawn
shawn.54
Ok thanks a lot will get that and try to replace before weekend thank you again Shawn
shawn.54
What about line from pump to middle carb my boat is out without me this week having fun while I'm at work.
Chinewalker
Typically the larger hoses are 5/16" and the small bits are 3/16". If you have several feet of both, you'll have your bases covered.
shawn.54
i noticed that 1 of the lines looked distressed so I will replace all thanks again for the help.
Shawn
sutor623
Chine, I thought the distribution lines from main to carbs was 5/32"?
gm280
Obviously there are many folks with many ideas as well about what size fuel lines to use. If you really want to get serious about fuel line size, you could calculate what the maximum fuel your engine could possible use at WOT and then do the math to see what size fuel lines can provide. That IS what the design engineers do. But I say skip all that and buy what is originally on there now and happy boating... It really isn't that difficult! JMHO!
