99 4.3gl will run in start but not the run position?
jrluhm
Like the title says. The boat will run with the key on the start position but as soon as I put it in run it dies right away. I've changed the ignition fuel pump cap rotor kill with and fuel filter. Is it the alternator or is there a relay or something. Hidden I can't find
Thank for the help
dypcdiver
Alternator supplies power to the fuel pump once the engine is running (stopped cranking) via a cable that has a diode in line.
jrluhm
I've read something bout maybe the diode has broke. Is that an option or alternator all the way
Lou C
Have you checked the ignition switch for power in the run position?
jrluhm
It's new and my radio works in the run position so I'm assuming I got power
Dave-R
If you have ever jumped the battery to the wrong terminals, it blows the Alternator side diode. They are built right into the wire that feeds the pump from the alternator.I think it's the green wire. When you are cranking, the starter provides power to the fuel pump relay, when it's running, the alternator takes over. The two diodes protect each source from back feeding each other. Dave-R
jrluhm
Is the diode on the wire Goin from fuel pump to alternator? I have no green wires on alternator
jrluhm
99 4.3gl will not run with key in run position
Just as it says. The motor will only run when the key is held to start position. I've changed the safety switch ignition switch fuel pump and relay and I've checked the diode coming from the alternator to the fuel pump. All is good. Am I missing something
Thanks
Is it running out of fuel or is the ignition not working when in run position.
Isn't this the exact same question you posted a few days ago?
jrluhm
It's not fuel. I've hooked the fuel pump up direct and still the same. Yes I've posted something similar a couple weeks ago.
You have voltage at the coil with the ignition switch in the run position?
GA_Boater
Jr - Please don't start new threads on the same problem. All that does is confuse members and you get the same answers again
Verify the suggestion in post #11. If you wired the fuel pump direct and the pump is running, then you aren't getting the "run" voltage to the coil, only the "start" voltage.
Isn't this a carbed V-P? You've been chasing your tail with all the fuel pump stuff when all you had to do was look in the carb to see if fuel squirted when the throttle was advanced. If it's injected, all you had to do was see if the fuel rail is pressurized by depressing the Shrader valve on the rail.
You've thrown a lot of parts and money at this and from what I can tell, no further ahead.
jrluhm
Yes no voltage to the coil. I meant to put that in the original post. Not sure where I'm loosing the voltage
Ayuh,.... Start at the key switch, 'n check with a test light for power to the ignition circuit,....
jrluhm
Got it there and all the way to the alternator but not the coil
jrluhm
New kill switch I'm assuming that's before the alternator and I've got power to it. The relay in the box where all the wires plug into. Would that have anything to do with it
The kill switch is after the ignition switch and has zero to do with the alternator. What are you talking about?
jrluhm
On the left exhaust manifold. It's got the 2 50 amp breakers on it and then behind there is a relay.
That's not a kill switch. I am talking about the switch you hook your man overboard lanyard to.
