stingray99
Thread starter- Joined
- Aug 28, 2005
- 2
I have a quicksilver 3000 classic remote control p/n 827720a23 and a mercruiser 3.0 stuck in neutral.At first the throttle only button seemed to be stuck.I took the unit apart and the only thing I found was a white plastic bushing that has a slit down the side which I don't know if this is normal or cracked.The throttle button works fine now.I don't see anything wrong in the remote control unit itself but when I put it in forward or reverse it stays in neutral.I don't see any movement on the shift cable assembly on top of the engine.Should I? I checked service bulletin 99-6 shift assembly equipped with shift assist and it looks fine.Where should I go next, either take apart the shift cable at the remote control or top of the engine to prove where trouble is? The shift cable is in the original location when the boat was new with no kinks or bends.
