Suprathepeg
Thread starter- Joined
- May 25, 2015
- 259
OK so which of the solas should I get the Rubex or Amita?
As long as the level isn't so high that it is overfilling, how do you think that actually makes a difference?Only issue we ran into is the float on the carb it a little high for slow speed running.
So I grabbed a Solas 21p as recommended it ran ok but tons of slip. Max speed was 34mph at 4800rpm which is the same as with the old worn 19p.
One catch is that it wouldn't clear the standard trim tab so I received the tap to give 1/4" of clearance. The wake seemed pretty violent with a lot of spray. I don't know it it's a trim tab issue or not, today I picked up the proper high rake trim tab, plan to test the boat again tomorrow.
I haven't drilled any vents yet, hopefully start messing with vent holes tomorrow.
