artfan1
- Joined
- Aug 14, 2015
- 71
Yup you NAILED it!!! That's a good Deal on the insert!!! With patience you should be able to straighten the RR make it work or at the very least only have to purchase a small length of it. I'm a C.O.B. so I know ALL about pinching penneys and saving a buck when and where you can. If you check out my restoration thread you'll see many instances where I "INVENTED" a lot of things to get the boat put back together and she works just fine!!!!![]()
I like the idea of using as much original as I can anyway, so that always saves some money. I'll work on the aluminum rub rail this winter when I am stuck inside. Both you and gm280 feel it can be straightened out so I'll give it a try. Maybe I can but parts of it are pretty bad.
The insert has a lot of areas that are discolored. Pinks and greens. I'm guessing it's from algae and Missouri clay maybe? Depending on how nice the restoration looks at the end, and how good my paint or gelcoat comes out, I might want to put clean bright new insert in there and the price for this insert isn't as bad as what I was hearing others have had to pay for theirs. Also, I love your restoration thread of the Lonestar Flamingo. I've been reading through it. Lots of great information.
I following this one. This looks like a fun project. Good luck on the cap removal.
Thanks for the encouragement and for following along.
I wanted to ask you this for sometime now.... If it is not so much trouble, can you post a picture for from inside the boat under the gunnels where the cap meets the hull. I want to see how it looks like before you start cutting. You posted a drawing of it before but I would love to see a picture if possible
Sure thing. I will take some tomorrow. It's not consistent all the way around so I will take a few. Might even take video since it's hard to really get in there and focus the camera. I wish I had my son's GoPro right now. He's suppose to be bringing it to me.
One good thing I found out today is that the area in front of the casting deck, (the fat part of the cap at the bow), doesn't have all the tabbing. So I most likely won't have to wrestle with that part to cut it loose from the underside. I have one of those "borescopes" my wife bought me a few years ago. It's pretty good at seeing into tight spaces. I used that to look around under there and it looks to be free of any added layers of fiberglass. So that's good.
