artfan1
- Joined
- Aug 14, 2015
- 73
Everything that everyone said makes sense and I am moving forward for now. I'm glad to hear that there are processes later that I can use to correct this twist. I just wanted to be sure it wasn't an issue now.
I thought today was gong to be a total bust. Rain, rain, rain. Then late afternoon, it stopped and the sun came out.
So, I grabbed everything and suited up. I managed to get the cap cut loose from the bow to the stern on the starboard side. I know, not much but the other side should go a lot after for me.
Only one area that was an "uh oh". It was more like a "%#$@!", but I didn't freak out too bad. I know it's likely an easy fix… right?
That area was tough for some reason. There was about 1/4" of solid resin there and I just couldn't get through. I put a new blade on and it cut through, but not as perfectly as I had hoped. But I figure 2" of damage out of 16' of cutting isn't too bad.
Tomorrow I will hit the port side, then the stern across the transom. There is a very thick area there that looks like the cap extended about 1/2" past the hull and was filled in with something. I will post a good pic of it before I start cutting that area.
