How to bypass vro oil pump johnson outboard 150 hp
sfmaster
Me again, :)
I took out the boat this morning all working fine. I had to take the boat out to fix a small leak (lose clamp). Went back onto the water and my tilt/trim only goes down now and won't go up. OMG what bad luck. Now I 'm out of the water trouble shooting the issue. Relay was taken off to see if dirty , but it was clean. I don't know what happen . It was working fine this morning. Any ideas , please!
Those motors do have a trim limit switch. It is located at the trim pivot point, and is pretty obscure. Maybe one of the wires disconnected?
Bill kubiak
Go to the top secret file at the very beginning of this forum. Click on it and then look for VRO conversion in it. Tells how to disconnect and use premix. If it was me, I'd still disconnect it. JMO.
l also cannot find any Top Secret File anywhere, should I email HILARY
