Enough fuel?
97_Manta_Ray_CR
Hello to all
My question is regarding fuel consumption for my 18' manta ray with a 99 mercruiser 3.0. I would like to take a little day cruise down the river and head back, the boat has a 30 gallon tank I my one way trip will run me about 40 miles down river. My question is do you think I would have enough fuel for a round trip with myself the wife and a cooler for drinks?
Thanks again
Chris
My initial assumptions would be yes, using 4 to 5 GPH at about 25MPH. The 3.0 would burn around 10GPH at WOT. So 25MPH you would burn about 8 to 10 gallons. The down river part will be reduced by the current in the river (25MPH cruise, 3MPH current = 28MPH), and will also be increased by the up river trip. Maybe 15 gallons back up, so estimate 25 gallons on the high side.
Now you should know how much fuel you use every time the boat is out for the day. How much run time is there and how much fuel is used?
thumpar
I only had a 18 gallon tank on my old boat and would run 25 miles one way ,50 total, with no problems. There was even a little tubing/playing on the way. As long as you are cruising you won't eat up too much fuel.
Bt Doctur
you could get 2 outboard tanks and run 1 tank at a cruise setting and one at a slow cruise setting and see how far you go on each one.
then use that info for the built in tank
Or install a fuel flow monitor and know at any point in time what fuel consumption is.
HT32BSX115
I would agree. I installed a LOWRANCE LMF-200
http://www.lowrance.com/en-US/Products/Gauges/LMF200-en-us.aspx
There's no better way to know FOR SURE if you have enough fuel at any time.
Otherwise, you need to have a spare tank you can switch to if you run out.
Even more important than MPG is GPH (gallons/hr). Why? If you pull away from the dock, get on plane, throttle back to cruise RPM and the GPH display shows something way different than normal you turn around and head back. This is an instantaneous reading. MPG is an "average" of fuel used distance/time. So you could be well into a trip before excess fuel consumption is noticed. MPG is also highly variable based on load, water conditions, wind, etc. Yes - GPH is affected as well but again, the reading is instantaneous so you can make minute by minute plans as to whether you need an alternate route/plan.
HT32BSX115
Absolutely. The above gage not only measures/displays GPH, but will also tell you how much fuel you have left by calculating total fuel used (or fuel remaining) regardless of how you operate the engine. If there's a GPS on the network as well, it also will give you MPG, and miles remaining etc.
