Picture of an outboard motor on a pontoon boat
Silver Eagle
As you know it's very hard to see if your motor is to high or to lower in the water.Does anyone have pictures of a motor in the water at the correct heighth ?Also Sometimes We have problems with the trim.
Pontoon outboards operate in very turbulent water so I suggest it be mounted full down. If yours is not, that may account for the trim issues. Tri-toons may be able to tolerate higher mounting.
ahicks
My first try is generally with the cavitation plate flush with the bottom of the engine mounting pod. If that doesn't work out, adjust as necessary.
Reel Kahuna
Hopefully this may help.
Silver Eagle
I don't have a trim problem, The problem is where people want to sit.
ahicks
Not sure what that may have to do with correct motor height?
1983 ercoa 21'
If everyone sets on the front it would make a difference in depth of the motor in the water.
I believe what he is getting at is the adjustment of the depth of the motor depends on
how it sits in the water under normal load.
ahicks
Seems like "correct height" would be set to allow for a boat in motion. If it was set for just sitting in the water with a lot of people on it, as soon as the boat gets up a head of steam the prop is going to come out of the water. Or am I missing something?
Silver Eagle
Yes, you are missing something .You guy's are thinking ahead of your selfs..I just want to see where the water line is when the boat is sitting still.
ahicks
Sorry for the misunderstanding. On average, I'd say many/most waterlines are about halfway up on the back of the pontoon.
HotTommy
I hope this thread doesn't end before I figure out what its about.
ondarvr
That's pretty much irrelevant, the concern is where it is when running.
ahicks
Nice to see I'm not the only one trying to figure out the question...
garbageguy
what? hopefully RK answered your question
Silver Eagle
I just want to see the water line on a out board motor sitting in the water, Not moving. What's so hard about that?. Is it too high ,or too low or what.
ondarvr
It makes little difference, there isn't a too low or too high while sitting. Well I guess if the motor was completely under water or raised up out of the water it would make a difference, but other than that the position is determined while running.
1983 ercoa 21'
I have always lightly loaded my toon and raised the motor till I started having cavitation problems then dropped it one notch.
