1978 tower of power hard to start
cuenta619
Is very hard to start need put little starter fluid
The fuel pump was rebuild the button carb. Had gas leak from butterflies I adjust the float level and stop the leak but now is very hard to start
Any suggestions.
gm280
Is your choke or enriching system working correctly. Doesn't sound like it and I would start there and see why not... JMHO!
Chinewalker
Make sure the choke butterflies are closing all the way. Not uncommon for 40-year old bits to get sloppy with age and not work as they should...
cuenta619
I will check .
I see the choke move when I push the button
Update :
I have a deep cycle battery and I see the motor turn slow. can this be causing the problem.???
but as soon as I spray a little starter fluid the engine starts immediately
Mi duckdown
I would not use a deep cycle battery for that motor. motor not turning fast is part of your problem. I would quit using starter fluid
cuenta619
Yes. I know the starter fluid no have lubricant. !
I fill a bottle with premix 50:1 to sprayed
Any suggestions to a good battery to this motor
I test the battery in NAPA and is good 12.6 vol.
And 650 crank capacity.
but maybe not enough
A series 24 battery 650 CCA is plenty strong to start that motor. I would recommend you clean the battery cables at both ends. Look for bulges under the insulation indicating corrosion. Check the condition of the quick disconnect plug. They can get corroded.
Run a good battery cable from the battery to the starter solenoid, and a new ground cable as well, and see if the motor spins faster when starting. Check/clean the starter ground cable.
cuenta619
I check the cables and the positive cable to battery side have the end terminal loose and corroded and when crank the cable get overheat.
Today I will change. The terminal
