TN-25
- Joined
- May 27, 2008
- 625
Greetings. I have an old cedar strip square stern canoe that my father had built for him right after WWII by an old boat builder in Orillia, Ontario. In the 1960s after knocking a small hole in the bottom of it, he plugged the small hole then used fiberglass mat & resin to cover the entire outside of the hull. All these years later the hull seems to be quite solid, but I really want to strip off all the thick, cloudy, lumpy resin and mat. The idea is to strip it right down, repair and refinish it. I am thinking restoration here. I have dad?s original 1950 Johnson TN-26 that has now been fully restored and would look perfect on the stern. Dad said it would plane with the 5-horse Johnson TN on the transom. He bought that motor to replace the 2? horse late 40s Johnson HD he originally ran.
I have tried using coarse sanding blocks but it is an endless chore that could take decades at the rate it is going. Should I try a torch and a scraper, chemical stripper, an orbital sander or something else? I do not want to damage the hull if I can help it. I don?t want to gouge it and I CERTAINLY don?t want to set it on fire.
The canoe has only been in the water less than a dozen times since the dawn of the 1970s and hasn?t been on the water since the early 1980s. When not in use it has been suspended inside a garage since about 1950.
Thank you in advance.
