ibrw1
Thread starter- Joined
- Nov 13, 2010
- 254
L-345059 Thought it was fixed. Backfire intake manifold. had boat for three years, then backfire issue starts and I did the following; Set Base timing by jumping purple with white stripe to ground, then starting engine. Idle is truly 650 at set timing to 10 degrees before. NOTE timing chain is good, strobe NOT jumping all over, indicates chain is ok. Bought rebuilt carburetor and tuned it. Idles great, lots of power. Still backfires. I put in all new AC MR43LTS as requested on air cleaner. Still backfires. Bought new rotor and distributer cap. Kit #805759Q3 QuickSilver OEM parts. Still backfires. I quadruple checked spark plug wires too. They are going to correct locations. I bought a new gas filter/water separator. Issue is getting worse. Before, engine had to warm up, and had to be running near WOT Then, next trip, it fails between 2900-3500 rpm Only after engine warm up. If I idle or go slow for 10 minutes, no problem. Runs great, then back it comes. If at slow speed and I put the hammer down, it never backfires. You know, going through the danger zone. (2900-3500). So all new plugs, carb, filter, rotor, distributer cap, setting special base timing and adjusting fuel mixture to exact specs. New gas, no clue here. thoughts? All OEM parts. I am very meticulous. Outdrive is 2 years old. All new parts.
