Woodonglass
- Joined
- Dec 29, 2009
- 25,930
Soooo, what paint did you use???
It's funny you posted this. I just bought a Gallon of the same stuff to try on my outdoor furniture. Gunna give it a try and see how it performs. I even bought the Water Based Acrylic Clear coat too! I'll let you know how it works too!!! How come you get it Free??
I wondered about that water base aluminum primer rusto makes. Personally I've never seen a lasting paint job with oil and water mixed but a water based primer and top coat should be fine. Looking forward to seeing the results.
Looking good....I've been thinking about spraying the inside of my boat....but after seeing what you did rolling could be a option.
So I was finally able to evict the Alumacraft from the garage and get it covered and the Pike has now moved in.
Was able to get some more paint on it today and also got the plywood cut and almost fitted to cover the side flotation boxes. Got the one side cut and fitted then used that for a pattern for the other side only to find the 2 sides are not the same shape. Grrrrr! I'll finish up the fitting tomorrow then seal them up with the "Old Timers Formula". From there it will be finishing up fitting and drilling the transom and the SS cover I'll be putting on it.
Observation on this paint so far. Have noticed it's taking a long time to cure hard as there are spots that still seam to scratch easily. Haven't determined yet if it's the latex on aluminum or if it's the lower temps. I know from experience with this paint that it does take longer to cure hard so time will tell.
Will try to post some pictures tomorrow.
Bonz, I moved your pix into the previous post and deleted the 'what now' post. Was that the edit you wanted to do?
Your post times werent very fair apart, I think the time limit for edits is still 1hr, so you should have been able to edit.
Nice fit on the side covers how are you finishing them? Painted?
