1989 Merc Alpha 1, Gen I, has been working "strangely" all summer. Had the drive off over last winter, had cylinders off as well for painting. After I assembled, the drive pump did not the same. It was kind of a "whirring" Healthy noise. After I reconnected, there was delays kind of sped up more I used it, ect. There is not loos of fluid, I did bleed the cylinders. Now tonight, it will no longer go up or down. It's the relay, It goes click every time I hit the trim. So, could a bad relay be doing all of this, bad connection, pump not getting all of the power it should, or is a bad relay a little more black and white.
Thanks!
Thanks!
