Squashtowner
Thread starter- Joined
- Jul 19, 2015
- 13
My 350 is siezed. I plan on pulling it out this fall and probably replacing it with a 4.3. Will an automotive 4.3 work in this application, or are marine engines different?
On another note, replacing a 5.7 with a 4.3 you will wind up more then likely with a boat which will have a heck of a time getting out of the water
So 350 it is. I hope a truck 350 is easy to find.I'm guessing a 305 wouldn't do the trick?
The boat is an 84, so I assume the engine is the same year. And I'm just curious about engines, a 4.3 had pretty much the same hp as a 305 and even some 350s. And they all had the same bell housing bolt pattern. From what I've read, and spoke with the original owners of this boat, it was an absolute pig on gas. So I'll do anything to make it a little more economical.
