Just got my new engine.. and gasket kit was automotive :-(
moparron
So my new (4.3 V6 - pre vortec) motor arrived this morning. I got home to give it a good once or twice over and noticed on the gasket kit they sent it's automotive. Now I am sad.. I am assuming that now I have ot tear down my new motor and replace the friggin head gaskets! I looked and they are fel pro gaskets, I assume form the kit they sent. Since I boat in brackish (salt) water, I really don't want to take a chance on burning up this motor.
Am I correct in my thinking?? Or does it really matter? The gasket kit that I recieved was sealed power 260-1241
Ayuh,..... Who'd ya get the motor from,..??
Mountin' the exhaust manifolds will be Impossible with those gaskets,....
Ya need one piece exhaust gaskets, so's ya can hold 'em In-place with 2 studs, 'n bolt 'em on with the bolts,...
GA_Boater
I would check the core plugs to see if you got steel plugs.
moparron
I did figure i would have to get exhaust and riser gaskets anyway since I bought a long block - so that wasn't a big deal. It's the head gaskets that pretty much tick me off.
i got the motor from a Marine engine rebuilder and figured it would have the correct head gaskets
Have heard about Repido for so many times, and everyone raves, but was always suspect because of other issues. What about calling them and ask about the head gasket?
moparron
All the freeze plugs are brass... they aren't painted - so its good there. I don't if the sealed power head gaskets are stainless or not. All I can see is the felpro "blue" . If they are stainless - then I'm good! :)
I plan on calling them this morning and asking them what's up with the head gaskets.
moparron
Okay... since Marc C mentioned that he thought the gaskets were stainless. I went into heavy research mode. The head gaskets in the kit are "permatorque" so I looked up permatorqe and found this:
PermaTorque SD gaskets get their strength and longevity from six key product features:
1. Armor Thickness ? Thicker armor creates a more detonation-resistant combustion seal, increases radial strength, and maximizes loading (and sealing performance) around the combustion openings.
2. Armor Material ? Use of high-grade Austinetic (non-magnetic) stainless steel increases radial strength, corrosion resistance and detonation resistance.
3. Body Core Thickness ? Solid-steel-core gaskets have higher radial strength than perforated core gaskets. ?Severe Duty? core material is 25% thicker than normal, further increasing radial strength.
4. Printoseal? Sealing Beads ? These enhance fluid sealing in strategic areas without removing excessive load from the combustion seal. They also allow the use of thicker armor.
5. Specialized Coatings ? These provide increased fluid sealing and anti-stick properties.
6. Hot Press Flattening ? Helps embed the armor into the gasket facing material, reducing torque loss. Use of heat imbeds the armor more deeply and consistently, and allows use of thicker armor.
Feeling a little less ticked off now
biggjimm
I'd call the manufacturer tech dept. Then there's no guessing. I've dealt with sealed power before & they were more than helpful. Good luck. Jim.
Ayuh,.... It's a steel fire ring, wrapped in ssteel,.... No problem, other than the multi-piece exhaust gaskets,....
smokeonthewater
SS around the cylinders but not around the water passages..... Personally I'd change em.
With a long block it'd take less time that typing in this thread... Almost
Ayuh,.... They're composite gaskets, the only metal is around the cylinders,.....
moparron
Been a while - But I thought I would post the newest on the motor. If for nothing else for future reference for someone searching for information. I had encountered several issues with the replacement motor. 1) automotive head gaskets 2) when I chased out the threads on the rear of the motor - one of the ears broke off 3) I believed I was getting a roller cam motor (which I did not).
I contacted rapido about issue number 2 when it happened, without the best of responses. when I realized the cam was wrong. I sat down and wrote a professional e-mail (not ranting and raving) of my experience. The next day they called me asking what I wanted.. I said I wanted the motor to be right - nothing more, nothing less. They issued a call tag for the motor that was in my garage that day and said they would build me the correct motor. Since everything was done on cell phone - it was a misunderstanding between both of us about the roller cam motor so that would be an additional cost. ugghh :-(
The motor was picked up promptly... but not delivered. Trucking company sort of misplaced it for over a week (Not Rapido's fault), they reviewed the motor - agreed there were issues with it. And sent me a new rebuilt which just arrived this last week.
Things I have learned;
1)be overly specific on what you expect from the beginning from any marine company
2)re-verify before item is shipped
3) run tracking numbers every day
4) There are still companies out there that will make things right
