Chevyboi001
Thread starter- Joined
- Jul 8, 2015
- 29
First off thanks for looking. Now I had my boat out 21 bayliner. Quick history I tore the bellow on water first time out when I bought the boat. Didn't inspect pds bearing or anything guy said ran great. Well I took on water sank tha back half, destroyed the flywheel housing. I tore the boat all apart rebuilt the engine all new bellows hoses and manifold. New flywheel housing sourced used. Brand new shaft and pds already installed. Boat ran great after some minor tuning and props. Now I didn't touch the outdrive. Changed the oil it looked good called it and that. Ujoints seemed fine no play left those alone too. Now out on the water temp started to climb on plane. Took it out and ran home put it one the muffs found out I have a leak and the collar for the water pipe in the outdrive. No biggie I ordered the kit. No upon removal of the outdrive I found oil and water mix in drive oil, and water oil mix in ujoint bellow. As well as a busted ujoint bellow. ? Now I'm looking at resealing the outdrive and installing new bellows. I'm not a Volvo penta mechanic I'm a auto tech. How or what could have caused a year in a brand new vp bellow? Also I'm reading that if I have to change the collar on the yoke seal I'll have to re-shim gear box. That's what scares me. What are the chances I mic the new collar and the collar mic the same. Or I polish the crap out of mine if it's rusty? I don't feel comfortable reshiming. Also I'm gonna do the ujoints all gaskets and bellows.
