Eoughphily
Thread starter- Joined
- Dec 29, 2014
- 63
I am hoping somebody here can point me in the right direction. I have spent the last two days working on this motor trying to get it running. A little history before I talk about what I have done. Motor has been running good, but lately has been getting more and more difficult to start. Once it finally starts, it runs good. I decided to address this three days ago. It all started with new spark plugs. (I replaced coils and spark wired 6 months ago when I bought the motor). I got j6c plugs, and was still difficult to start, bug holly smokes I swear it doubled the power and I believe it was actuslly running like a 40 hp should, speed wise. However I noticed the idle was a little rough. I pulled up to the dock for a few and after that have not been able to get it started. So far, I have replaced the condesors and points (made sure points were clean after install). Timed it using a voltmeter (instead of .020 gap, got this method off of youtube) by lining up the timing marks and setting points to just barely not touching. I verified I'm getting spark by pulling plugs and grounding them on the motor, turned it over and watched the blue spark. Done on both plugs. I checked compression, 82 lower 80 upper with both plugs removed at the same time, same as it was when I got it (started easier then) I pulled the carb, wasn't much to clean if any at all. It was spotless inside. I performed a cleaning anyways focusing on the low speed jet, but checking all other passages as well. Cleaned the fuel filter, same as carb, very clean. Gas is new, came out clean from filter and from carb. Got my low speed jet set at 1 1/2 turns out. I prime the bulb, fills up the carb bowl, doesn't leak out like it would if float wasn't set right. But the motor just will not start. Gas is making its way out the exhaust which tells me it's getting gas (mixed 25:1, roller bearings pre 1965) after trying and trying to start with no luck, barrel full of gas/oil in the water, half a squeeze on the primer bulb and its hard. Tells me fuel pump is working, got fair compression, got spark, timing should be good as far as I can tell. I am all out of ideas here. Thought maybe the kill switch, but I have spark. Unplugged it to test anyways but no change. Please if anybody has any other ideas. Also as for spark, I have an inline light spark tester but not an air gap tester. Currently broke and can't afford one till next Friday.
