bob johnson
Thread starter- Joined
- Feb 25, 2009
- 4,306
In the process of rebuilding a Starcraft I have, I ran into serious issues with SS hardware galling, and locking up , long before it was cinching up the items I was trying to bolt together. This is happening with SS 1/4-20 pan head screws as well as hex head bolt when I use SS locknuts.... I eventually reduced the percentage of ruined bolts when I started to grease the threads prior to installation. I am thinking it is probably the type of SS they are using.. I was getting the nuts stuck when threading them onto the bolt after threading on over 1/2" with a good 1/4" still to go and they lock up so tight, you cant even remove them!! Its NOT crossed threads. ITS GALLING...I have cut off about 50% of the bolts I used on my transom!! Another thing that irritates me is how easy the Phillips head driver indent in the pan heads strips. the SS is just sooo soft... I tried to buy torx head but they only offered them up to 2" and I needed 2.5".... thus I eventually went with hex head bolts...at least I can hold the head while I tighten the nut!! I really think it might be a material issue or a quality issue or a combo...because when I bought some pan heads bolts from one hardware store , I could hold the Phillips head with a screw driver while the nut was tightened very tight...but all the ones I bought elsewhere would strip at 1/2 the torque! unfortunately that store ran out and hasn't replenished in a month! anyone else has this kind of issue with SS hardware???
bob
bob
