Anyone have any advice or info on a 75hp 1975 Johnson stinger? I just bought a 75 starcraft ss that the motor is on. It started easy when cold, ran strong. I then restared it about 15 minutes after shut down it it fired off as sonn as I hit the key and sat there and idled. I guess I should replace the impeller as the PO said it was done about 4 years ago along with the thermostat. The tach is not working but he thought the gauge itself is bad. Can I install a temp gauge on this? Is there a way to put a tell tale on this motor? Anything else aside from lower oil change and some routine MTC I should do before running it. It will probably get winterized now as I doubt I will have time to get it on the water before the winter rolls around. Just thinking ahead for next spring. Thanks in advance.
