lindy46
Thread starter- Joined
- Nov 27, 2008
- 3,886
Working on a '62 Johnson 5.5hp. I've gone through everything and once I get it started it runs pretty good. It's just getting it started that's a pain. Takes 25-30 pulls before it even farts. Compression 75psi and even. All new electronics - points are properly set and cleaned with acetone. New wires, new plugs. Spark jumps a 3/8" gap. Carb cleaned and rebuilt. New hoses. Did a decarb with Seafoam. Even spraying premix directly into the cylinders won't give a sputter when cold. You just have to yank and yank and finally she sputters, then starts. Low speed needle is open 1.25 turns (yes, I cleaned under the freeze plug), but high speed is only open 1/8 turn. Any more and she dies. Good fuel pump. Any ideas?
