OptsyEagle
- Joined
- Sep 13, 2006
- 1,367
Well, there has to be something that you currently think is correct, that is not correct. You have OK compression, you have good spark, it is timed well from your point gap and spark plug wires going to the right cylinders and you have manually put fuel into the cylinder holes and it will not start. Even with crankcase seal breaches I would think it would pop with fuel put directly into the cylinders.
I would start at the beginning and go back and test the compression, spark and perhaps for a quick test, try a different fuel into the spark plug holes. Pull the spark plugs and rip on the cord a few times to make sure any residual fuel is out of there and not causing a flooding condition. I sometimes use seafoam to quickstart it. It is combustible and has a small amount of lubricant. I would even switch the spark plug wires just to be sure. Not to keep harping on that one but your problem is beginning to be quite the mystery. From what you say is correct, the laws of physics says that your motor should be purring like a kitten.
