gm280
Thread starter- Joined
- Jun 26, 2011
- 14,605
I bought four nice stainless steel cup holders that mount into the hull for a flush mount design. And they are nice and have a threaded section in the center of the bottom to accommodate some type drain tube. I understand how to mount them, but what type drain tube have others used for the drain and what type fitting do you use to allow a nice flush mount opening where the drain come out? The thread section have a plastic thread part the fits on the drain section but I can figure out how it is used with the tube. Any ideas? This is what they look like;
As you can see the center threaded drain section. But how does a drain tube fit on them and what is used at the other end to terminate the outlet? :noidea:
