sutor623
Thread starter- Joined
- May 23, 2011
- 4,089
Hey guys, I have installed some clear hoses in my fuel system to find an intermittent idle/hard start issue issue. I have found enough air coming in from the gas tank to concern me with leaky fittings. I have isolated the air as coming in after the fuel tank and before the fuel/water separator.
I have an aluminum tank with aluminum fittings. There is an anti-siphon valve installed. Would it be appropriate to just tighten the two fittings 1/8 turn with the wrench? Or do I need to full remove the fittings to check the pickup tube and the re-apply thread sealant to the fittings before tightening back down? I am concerned that I will crack a weld or damage the aluminum fittings if I remove them.
